fullmetaljacket
- 11:14 PM
- Oct 15, 2010
- Brooklyn, New York
Mounted on the spindle with a Wagner finless drum. This is the lightest drum out there short of a 1980's Chevrolet aluminum drum. The vibration spring ring has since been removed because it was in sad shape, but it took off a few ounces. Some drums out there will not hold balance well without this spring ring but this assembly lucked out with vibration free service. Drums are different from different manufacturers.While the wheels are turning on the subject of wheels, here's a little subtraction of weight on the rotating end of things with an aluminum hub assembly. T-7075 material. I'm not next to the numbers at the moment, but the weight reduction wasn't that much, perhaps a pound or two.
