- 11:00 AM
- Oct 25, 2010
- Monroe, New York
Suncast shed at BJ. Floor display on sale.
Even a crappy day can turn out nice if you have a few beers with some friends.Turned into a good day despite not going according to plan.
View attachment 1484554View attachment 1484556View attachment 1484555
Does that include an environmental fee?View attachment 1485761
Prince street Pizza off Huston Street lower Manhattan NY. Spicy pepperoni. Will cost you $7.00 a slice.
What was the cost difference between spray foam and the rockwool ?Finishing up a miserable job! I wanted the floor spray foamed until I got a quote, decided to try something else instead. R30 Rockwool then 2" foamboard cut at a 10 degree angle so it fits tight but still lets me spray foam it in air tight. In theory, it should be as good.. maybe better than foam? View attachment 1485805View attachment 1485802
What’s the size on that looks good.getting closer, working on it all of this coming week, if it doesnt kill me IView attachment 1481771View attachment 1481772View attachment 1481773 should be close in a week just me and another senior citizen one panel at a time can't wait for the roof, crazy it goes on last.![]()
A lot! I think I spent about $1,000 on the Rockwool and 2" foamboard combined and they wanted $6,000 to spray it.What was the cost difference between spray foam and the rockwool ?
I laid 2" foam under a radiant pad in my other garage and would do the same again if I had the choice. You say almost impossible, I say easily done. I compacted #56 gravel down then put a good bit of sand down, levelled the sand, compacted it then checked the level again. When it came time to lay the foamboard the prepped surface was probably more perfect than the concrete lol.When we built our home 10-11 years ago, I went with spray foam in the basement , including the floor due to radiant infloor heating. The expense was offset by some of the advantages (no additional vapour barrier required for one thing). The attached garage/shop is 26' x 48' with radiant infloor heat as well. I opted to save $1000 and go with 2" sm foam sheets under the floor. I regret that decision, the sm foam was near impossible to get laid level without voids. Spray foam would have been a better choice, even at the extra cost.
Rockwool is better at acoustics than fiberglass, it is also fire retardant as well if that is a consideration.
The cost difference is way bigger in my area. They make Rockwool for both insulation and sound deadening, I used it because it being a floor I was concerned fiberglass would eventually settle in the joist.. Rockwool is like a firm sponge.When we built our house, the cost difference between spray foam insulation versus traditional insulation was about 1 1/2 times more. We went with traditional insulation.
I may be wrong, but From what I understand, rockwool is used for sound deadening.
Wow cost unknown huge money at least for a po boy like me. Like it! Location looks nice visited in the 90's but that crater ain't dead. Would homeowners insurance cover that. Don't mean to be a downer but that thing is only sleeping.Here's a spray job on the geodesic dome my brother and his wife are building off-grid on the southern flank of Mt. St. Helens. He has semi-retired and is living there full-time in the basement while they finish out the dome. Cost unknown.
The dome:
