Disc brake conversion
Paul73
9:05 PM
northern Kentucky
Hello, I have some questions about front disc brakes on a 69 road runner. My road runner is a four wheel drum brake car. The brakes work decent but aren’t great and I have a 440 in it so I really want good brakes. I happen to have a set of brake calipers and pads that were going to go on my 73 charger but I’m going a different direction with that and I have these calipers sitting around. They are the pin type calipers. I was wanting to use these calipers on my road runner but they obviously don’t bolt right on. My question is what kind spindles would I need to mount these pin type calipers on my road runner? Would a set of 73 charger spindles work? Same thing with the brackets. Never done anything like this before. Any advice would help.
Paul
Pin type caliper adapters come in 2 sizes 10.75" rotor and 11.75" rotor. The larger rotor ones very expensive if you find them. Recommend you buy a kit, dr diff is one. If your running 14" 2 wheels be careful to make sure kit works with them.
I agree the Dr Diff kit is the easiest route and best bang for the buck. I prefer the 15/16 manual disc brakes and do not miss power assist.
Pin type caliper adapters come in 2 sizes 10.75" rotor and 11.75" rotor. The larger rotor ones very expensive if you find them. Recommend you buy a kit, dr diff is one. If you’re running 14" 2 wheels be careful to make sure kit works with them.
Ok, I am in fact running 14” wheels. I will watch out for that.
