If you just install a pinon snubber, you'll probably still have a violent wheel hop. ESPO will make you springs with whatever ride height you want, +- inches from factory height.
I would try the snubber first.
If the OP is experiencing this condition
under just normal accelerations.
If he's jumping on it to the point of
abusing the system there's no way to
tell if the springs are the weak point,
without knowing a few more
parameters. More umph in the engine,
lower gears, snubber in place, etc.
You'll get wheel hop in just about
any car with leafs if power plants
and traction conditions can overdrive
engineered designs. One step at a
time, and no second guess.
