64sleeper
First time out with the car yesterday. A little more tuning and we should be in the 10s no problem
couldn't have done it with out your help! hopefully we'll both be posting in the 10 second section real soon^^^ Awesome job Walt. Another 64' saved and back on the street/ track.![]()
Wow, that's light, I'm at around 3610lbs (3860lbs with me at the track) with aluminium heads and just header extensions in my 71 R/T. What have you done for weight reduction?1973 Dodge Charger
1964 413 Block .030 over, steel crank, LY rods with ARP Bolts.
Sterling stock replacement pistons (appx .060 down)
Melling HV Oil Pump
Miladon 8 qt pan and pickup
906 Heads, milled .100, stock size valves.
Gasket matched intake ports and bowl area ported to the DC templates.
Compression ratio is roughly 11:1
Lunati Hydraulic Cam Part# 10230906
In Ex
.509 .534 Valve Lift
235 245 Duration at .050
Rhoads Hydraulic Lifters
Lunati 73815 Single Valve Spring W/ Damper
Rocker arms are stock replacement TRW Stamped steel with matching pushrods
Edelbrock Torker intake.
Quick Fuel 850 race carb (OOTB tune).
Aeromotive electric fuel pump into a Holley dead head regulator 7 psi.
8 gallon fuel cell in the trunk.
I mix 2 gallons 110 race fuel with 3 gallons 93 pump gas.
Ignition system is an MSD 6AL-2, vintage MP distributer (orange box kit), and Accel Super Coil.
Cooling is a stock water pump, aluminum stock type radiator, Mopar clutch fan. Runs at 180 degrees.
1-3/4 Hooker headers, open when I race.
30 lb Ram steel flywheel.
RAM 6000 Series Sintered Bronze Clutch Disc
RAM Super-Duty Long Style Adjustable Pressure Plate
Lakewood Bellhousing
Mechanical Clutch Linkage
Clutch Tamer
1968 23 Spline 833 trans, lately fitted with faceplated 2-3-4 gears from Liberty (Muy bueno).
Vintage Hurst Super Shifter III with custom pistol grip stick.
Strange Chrome Moly Driveshaft
Strange D-60 Rear, Spool, 4.56:1
Calvert split mono leaf rear springs with Caltracs
Viking DA rear shocks, QA1 SA fronts
Rear Tires Hoosier 29 x 10 x 15 Slicks
Front tires are Mickey Thompson ET 27.5 x 4 x 15
Vintage aluminum slot wheels all around
Battery in trunk.
Lift off fiberglass hood
Manual steering and brakes
Sub frame connectors
Weight is 3405 lbs with 6 gallons of fuel, 3655 with me in it.
Launch around 4500 RPM, shift 5800, trap 6200.
Best time of 11.824 at 114.65 at Dragway 42.
It surprised me when I weighed it at the track this summer. About 150 less than I thought it would be.Wow, that's light, I'm at around 3610lbs (3860lbs with me at the track) with aluminium heads and just header extensions in my 71 R/T. What have you done for weight reduction?
Holy sh*t that thing is making some steam. I'm getting the same 1/8 mph, but down about 4 on the top end. I'm probably 6 700 lbs lighter too.1969 Charger
4,100lbs without me, 4,270lbs race weight. 15x8 and 15x10 wheels with CR6ZZ vintage road race tires.
Engine started as a 90's "crate" 426
3.75 stroke, 4.31 bore 12.4-1 CP pistons with .043 rings GZ vacuum pump.
Milodon 31580 road race oil pan. TTI headers. Dual 3" exhaust to stock type tips.
Iron heads, I ported them. Ferrea valves, 1.4" diameter PSI valve springs. Stock iron rocker arms.
Cam motion low lash solid roller 262/262 112lsa .658 .612 at the valves.
Edelbrock 2x4 intake I converted to EFI. Holley HP efi system, flex fuel/E85. Modular/coyote coils.
Cowl plenum air cleaner.
TKO600 trans. McLeod RST clutch. S60 with 4.56 gear.
First run I slipped the clutch out at 4,200 rpm and it actually hooked but absolutely obliterated the clutch. It was slipping down the entire track and flaring on the shifts.
I let it have a good cool down and tried dumping the clutch at 3200 but it just spun. I still pedaled it and ran it out.
Shifted it normally (with clutch and lifting throttle) at 7,750rpm.
View attachment 1549635View attachment 1549642View attachment 1549643View attachment 1549644
I keep thinking of little things.It surprised me when I weighed it at the track this summer. About 150 less than I thought it would be.
It’s really a lot of little things.
No back seats, or interior panels. The dash is currently stripped of the gage cluster.
I had to remove the heater box and stuff, along with the headliner because mice got in it in storage a few years ago.
I left most of the exterior trim off when I painted the car. I took off the big honking black things off the bumpers, half the front bumper brackets. I think I will get a fiberglass front bumper this winter.
Manual steering and manual brakes save a lot of weight.
Dana 60 added weight, but then I swapped out the super stock springs for split mono leafs and that took more off.
Aluminum intake and radiator.
Headers with no other exhaust.
Light weight aluminum wheels and tires.
Of course if I drive it on the street I put the exhaust back on and heavier tires and wheels.
No windshield wipers or washer.
Just bare bones stuff
Haven't tried the 7750 shifts, maybe that's the trick lol![]()
It's those weird " Hee- my heads"Manual transmission cars will mph a little better than an auto car with the same power to weight ratio, but agree with you. INTMD8 has 1-2 mph on my 1/8 mile but almost 7 mph in trap speed.
What a great running car. Love the rpm combined with the manual tranny. That's pegging the fun meter
Pretty solid 60' ! Nice buildHere's my stock stroke build - 448/727-11" converter/8.75-4.10. SRP's in at zero deck, K1 H beams, 84cc eddy's - stock valve job with backcut intakes, I opened up the runners to 218cc's and skinnyd the bosses.. XE282S/1.6 mancini arms. Eddy RPM intake- port match, 850 quick fuel DP, 1 7/8" headers- open tubes. 71 Charger R/T - 3860lbs all up with driver. Hoping for 11s. 11.283@ 120.61.
