Steve009
Having an issue with my right side torsion bar not holding weight as well as the left side. I thought it was an old bar that lost its tension so I purchased brand new PST bars, same issue. They are both installed when bump stops were removed and lower control arm is dropped as much as possible. Left is on the left and right on the right. Lettering both at the back of the bar. Left side goes in smooth with little effort to tighten it up. Right side needs to be turned in way more and you can feel the tension way more. If both adjuster bolts are screwed in the same amount I have over 1.5” difference in the heights side to side. Is there anything else I’m not thinking of? Adjustment anywhere else in the front suspension that could change this? I’m out of ideas. Not sure it matters but this is on my 64 sport fury.
