- 6:40 PM
- Feb 22, 2021
- Roswell, New Mexico
Hard to explain and possibly hard to
diagnose. Please put your thinking
caps on.
The wiring on this build is totally
custom.
After a first time on the road shake out,
things went well. Idle, temps, oil
pressure good.
Pulled in the driveway and parked.
A few hours later, tried a restart, an
audible click, then nothing.
We've installed a mini starter where
the cable stud barely clears the block
by 3/16".
Could this be the problem?
I've tried searching the forum and
could not find anything that mimics
the problem.
I've no idea where to begin tracking
down how to diagnose as electrical
is my weak spot.
Thru the build this has happened only
a couple times during various build
and test procedures. Always the same
fuse associated with energizing the
coil/distributor.
Any help here would be greatly
appreciated.
caps on.
custom.
pressure good.
by 3/16".
the problem.
is my weak spot.
coil/distributor.
appreciated.
