- 10:53 AM
- Jan 19, 2019
- Center of Massachusetts
Hi folks,
I finally got around to installing my Passon 5 speed. (bought it from a member, great guy). Life got in the way until I blew the clutch
. This is my 1970 RR. Taking apart something that was built/modified 20+ years ago you have to expect some surprises. It has the 130 tooth flywheel, and a 10.5" bellhousing, but..... It's a cast #2468372. Which fits except the bearing retainer has to be 4.354. I knew it was 23 spline however it functions just fine and the shifter is correct for a 1970 B body. The 18 spline 4.3.54 retainers are out of stock so I bought the replacement aluminum bell housing from Brewers along with a Centerforce clutch and some parts to refurbish the clutch linkage and of course my speedometer drive had blown out threads. I have a milling machine and lathe but felt lazy and I like aluminum. Plus, now I have a spare along with the old flywheel for dyno sessions
The good news is the new bell housing save at least 15 lb and it fit just about perfect. I was checking it with a dial indicator and couldn't believe the retainer opening was less than .001" runout, so I tried my tenths indicator and it was .0006".
So now that everyone can see under the old girls skirt, you'll notice I have a needle bearing (made in USA) rather than a bronze bushing. I checked the depth from the mating surface and the input shaft on the Passon 855 and have about .200" clearance between the bearing and the start of the splines. A visual inspection of the bearing doesn't show any wear or damage, so I'M looking for anyone who is using this setup to comment.
The current warmed over 383 is getting replaced the winter with a 440 (plan on 500hp as a goal). I believe the bronze bushing would handle lateral load better. Less moving parts
I can grease it, but it's not what I would consider easy to service. LOL
BTW: A shout out to Brewers for their excellent customer service
. This is my 1970 RR. Taking apart something that was built/modified 20+ years ago you have to expect some surprises. It has the 130 tooth flywheel, and a 10.5" bellhousing, but..... It's a cast #2468372. Which fits except the bearing retainer has to be 4.354. I knew it was 23 spline however it functions just fine and the shifter is correct for a 1970 B body. The 18 spline 4.3.54 retainers are out of stock so I bought the replacement aluminum bell housing from Brewers along with a Centerforce clutch and some parts to refurbish the clutch linkage and of course my speedometer drive had blown out threads. I have a milling machine and lathe but felt lazy and I like aluminum. Plus, now I have a spare along with the old flywheel for dyno sessionsThe good news is the new bell housing save at least 15 lb and it fit just about perfect. I was checking it with a dial indicator and couldn't believe the retainer opening was less than .001" runout, so I tried my tenths indicator and it was .0006".
