Anyone Running Dakota Digital?
dodge68charger
11:40 PM
Washington
If So How Did You Guys Route Your Wiring From The Sending Units To The Box?
Looking For a Clean Way To Drill Into The Firewall
You can use/share the tachometer hole with a grommet or drill a hole near the bulkhead and use a grommet there.
I shared existing grommets. I don't recall which ones, but it was no sweat getting them in.
Made up a bracket on my recent ’72 install.
Higher Res Picture
Made a Stepped Bracket That Screws Under The Dash. I Can Post Pics When I Get To The Install
I Haven’t Installed It Yet But This Is Where Its Going
Tucked Up Under The Dash
Checked The Clearance In My Roadrunner and It Should Fit
Going To Install The Dash In Mid January
