69 Charger 8 3/4 Axle housing Markings (Yellow "B" and Circle "X" on back or not?)
robl72
6:21 AM
RI
Trying to figure out the correct marking for my 8 3/4 axle housing for my 11/19/1968 Charger (Hamtramck).
I have seen some 8 3/4 housing marked with a Yellow "B" and a circled "X" on the rear of the Housing. Not sure if that is specific manufacturing plants or models.
If any has some pics of their 69 Charger with the markings please share.
Thank you!
Sorry about that. I don’t mean to dis the OEM resto crowd. But this is the drivetrain forum. And… I haven’t been on BAT in months. Tired of all the 911’s and old Broncos. But a ‘63 Split Window Fuelie Vette just moved for $250k. Another ‘63 SW Vette with an LS in it went for $280k. So the hot rod one was more desirable to the bidders. Probably because it will be driven.
Thanks…just trying to figure out what was correct for a 69 Charger hamtramck build.
That's interesting. Sounds like if you put the last two responses together you would have a Yellow X with a circle.... I am looking at two pics of OE Restored Daytona's online. I know they were done later in the year but I believe all Daytona's were Hamtramck too. I put the pics of them below.
Not sure if this helps but here’s my very Late ‘68 Los Angeles built Bee. I replicated these when I restored rear axle. Notice “B” with white dot on rear of housing. Axle code in yellow, date code in white. Small 1/4” white dots on bottom of brake backing plates I did not capture. Notice red daub on brake T bolt
Cool Pics. Wonder how much difference the markings were between LA & Hamtramck
