- 12:43 PM
- Sep 15, 2009
- State of insanity
I can't wait for my schedule to go back to normal so I can quit bugging all you guys lol
Been awhile since I did this but here’s what I remember,
- Radiator out of car
- Put fan on
- Lay shroud over fan up against engine
- Put radiator in
- Attach shroud to radiator now
Thanks for posting! Timing was perfect. One of those tasks that must be carried out in the correct sequence.Been awhile since I did this but here’s what I remember,
- Put fan on
- Put radiator in
Thanks!A clutch equipped fan would be easier to remove than the fan/spacer combo you currently have.
Where did you get the shroud form. Is it original. Just had a bad experience with one that was not original. Now have an original and going to be better than the other one. It is much more like it should be and not a flimsy piece of junk. Costly and had to get another radiator to replace the one that I just got. Not a happy camper.![]()
I can't stress this enough:
Get yourself a factory service manual for the car if you plan on working on it yourself.
It will save you grief, embarassment and yes, money too.![]()
So... I'm trying how to Tetris this thing on.. I have a 440 in a '69 Charger. Do I need to move the radiator support to get the shroud on? If I lift the radiator, I can't slide it down because the shroud hits the fan. I can't pull the fan because then I can't install the fan because it will be inside the shroud.
I'm feeling really dumb right now LOL.
I'm told the radiator is custom, though it looks OEM. One-piece shroud. Pic attached for reference.
Please help me stop being dumb. Thanks, in advance.
Bing, where did you source this conversion package you mention? The 67 wagon w/440 I recently purchased has a 22" radiator, wide core, but a hokey'd up shroud and fan. It gets very hot in the old stop and go. I'm going to look for the 2 piece shroud plus a fan that hasn't been modded in a couple of weeks when I go the Spring Fling in Van Nuys. In case the proper shroud isn't enough, I may have to do the 26" swap.WTB - Offset 26" fan shroud to fit a 69 Roadrunner. (18" fan) I'm changing out the 22" radiator to a 26" radiator by replacing the right side radiator support. (Conversion Kit). That's why I need it Offset - the left side and fan hole would remain the same but the right side would have about 4" added to the width.
