CoronetDarter
Dwayne,Sounds like a great time Rich and Greg! I wish I was there.
On my 68, I'm running the Lunati Voodoo 60302 with 112 LCA. After dyno tuning, at rear wheels (tires off and bolted onto dyno attachment) my motor made 391 hp / 523 ft-lb torque. With zero prior experience drag racing, out of 10 passes with Nitto 555R drag radials, my best was at Sac Raceway 90F temp, 12.80 sec at 108 mph. Car weighed 3700 lbs.
In retrospect, if I would have chosen my cam first and tailored the cylinders around that instead of the other way around, I probably would have gone 1 cam size up and have a motor that can take more than my current 32 degrees of timing.
Greg, besides the manual vs auto trans, did Dennis' 69 Coronet RT and Rich's 69 Coronet feel that much different? Dennis also has FF stage 2 steering. I've driven Dennis' car, but I'm surprised Rich's has no center slop. I hope it stays that way.
Brand:
Lunati
Manufacturer's Part Number:
60302
Part Type:
Camshafts
Product Line:
Lunati Voodoo Camshafts
Summit Racing Part Number:
LUN-60302
UPC:
090127606674
Cam Style:
Hydraulic flat tappet
Basic Operating RPM Range:
1,400-5,700
Intake Duration at 050 inch Lift:
220
Exhaust Duration at 050 inch Lift:
226
220 int./226 exh.
Advertised Intake Duration:
262
Advertised Exhaust Duration:
268
Advertised Duration:
262 int./268 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:
0.475 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:
0.494 in.
0.475 int./0.494 exh.
Lobe Separation (degrees):
112
Camshaft Gear Attachment:
3-bolt
Computer-Controlled Compatible:
No
Valve Springs Required:
Yes
Quantity:
Sold individually.
Notes:
3-bolt camshaft.
Your cam is a couple sizes smaller than mine. And you ran 12.80's. Not a lot of 12 second muscle cars running around these days.
