'73 Charger Power Bulge Insulation
Charger Fan
11:50 PM
Jupiter FL
Can anyone tell me if the underside hood insulation that fits a standard 1973 Charger hood is the same for the power bulge hood? I see a lot of insulation pads advertised on-line but none of them mention fitting the power bulge hood.
There are some vendors that sell them and you can find them on feebay. Your choice will be either regular cut pad or the molded cut pad. I have the molded pad. Of course the molded ones are more expensive. I have a Power Bulge Hood and this fits nicely. You can get these thru Detroit Muscle Technologies.
Did you purchase your from Detroit Muscle Tech? Was it recently? His website says it will not fit power bulge hood so I emailed him to verify. He confirmed he can’t advertise it as fitting because he has never had the opportunity to do a fit check on a power bulge hood. Sounds like you have confirmed insulation for a flat hood will also fit PB hood?
Yes that is correct. The fitted pad for the flat hood will work on the bulge hood. I did get it from DMT and that was 4 years ago. We have an All Mopar Swap Meet at the local college every winter and I also see him there with a large assortment of product for the 3rd gens which I'm sure I will be buying stuff from him again this coming Swap Meet.
I just found this one on the DMT website, but it seems it's not molded? They don't mention it in the description either.
I found this one on Ebay. Looks better?
