New rods, new pistons, new machinist. A point made by beanhead1967GTX is that basically - expect to know nothing until you start with parts in hand. I needed to have rough numbers to be able to talk to vendors as soon as I would be able to get them (numbers). Dyno day for me is $800.00 per session. I am not a math wizard but I'll use as much as I can find. So I'll be looking for as high amount of torque as the engine will make for the widest rpm range I can handle given the car's final setup. That is all the title really refers to. For me at this stage of the build that is a major focus. As you can see, at this point the car barely even exists. So tire sizes, gearing etc. needs at this point to be forecast to something reasonably close. So yes, I have little money for experimentation. As it stands I'll need two to three engine dyno sessions -- and maybe some guidance as well. So though on one hand the guy with the dyno's a good friend that I know will help out, on the other hand I wouldn't want to waste his time.Mathematical?
Was the previous owner keeping it in the living room or what?I've started a 440 for a 65 Satellite that from the factory ran a 383. There was no engine for the car when I Bought it.
The engine work's been started in that it was sourced from Michigan and according to the seller comes out of a mobile home.
Nice.
Could be. I was surprised at the condition.Was the previous owner keeping in the living room or what?![]()
We'll find out.Mathematical value = ZERO.....the car is a useless hulk and the $$$ you would need to spend to "fix it up" and make road worthy is simply not worth it. If you own it, sell it......
BOB RENTON
Yes. Didn't get the ones off the back yet.Got any photos or numbers off the block? It could be industrial 413. Reverse rotation is only from a boat.
I can take a punch.Tough day on Thursday!
Name a reverse rotation BB Mopar that wasn't used in a marine application. And what driveline that it was attached to.Reverse rotation is only from a boat.
No it ain’t !!!
So the engine was not reverse rotation. What would be the reason for turnibg the csm in reverse? Eliminate the timing chain? And then build a one off cam. Doesn't make much sense. Maybe for an industrial pump motor on LPG or propane that runs constantly.@dvw he is trying to say that some engines had the only camshaft turning opposite direction.
And of corse there has been no year, make, model, or application given.
Manufacturing a 'one off' cam probably wasn't a big concern for Chrysler, since those engines also had different heads, intake and exhaust manifolds, pushrods, distributor, pistons, timing cover and oil pump compared to passenger car engines. One more extra part wasn't going to be a deal breaker.So the engine was not reverse rotation. What would be the reason for turnibg the csm in reverse? Eliminate the timing chain? And then build a one off cam. Doesn't make much sense. Maybe for an industrial pump motor on LPG or propane that runs constantly.
I think that pretty much nails it.Eliminate the timing chain?
Thanks R413. The seller had it tagged "72 440" as though the unit had been inventoried. If that is the case who knows for how long and with what else it'd been sitting. At first I wanted some valve covers from the same guy but somehow missed out. It turns out that the ones on this engine were good and maybe better. He did say it turns good. Al Callaway at Burtonsville Speed and Machine told me, "Well careful because sometimes that could mean they're worn out". I jumped. I'm glad I did.This shows us a 1972 440 from a C-body car. Good engine to have for your hotrod.
so no reverse rotation cam, no other weird BS that will be mentioned on Friday the 13th!!
I was thinking the rotation of the earth.....I thought time would reverse![]()
