PRHeads
- 1:51 AM
- Aug 31, 2018
- So. Burlington Vt
Where were the peaks?
Was it run with the race car headers?
If not, do you know what size headers were used?
I have not seen the dyno sheet yet. I will get that tomorrow when I pick up the motor. Here is a pick of the motor on the dyno that shows the header that were used.
I ran a compression check on the cylinders. All came back between 148 and 152. I was expecting higher.
I have another compression gauge in my truck right now that I borrowed from a friend. We will see what it makes with this gauge.I’m not saying you don’t have 12.7cr.
I’m just pointing out the cranking pressure numbers don’t make sense.
I would value @dvw's opinion on that. My half assed guess would be... no. Victor and dominator against a factory crossram, oh yeah!While I don't like the idea of moving away from the Indy 440-25 intake with the dual eddy 750's, will there be a measurable performance gain by switching to a manifold like the Edelbrock Super Victor and single 1000cfm carb? I am trying to maximize the performance of the combo I have.
I know a few who have. Some have gained nothing. Some claim it's quicler. But I haven't seen it. Comparing a few similar engines to mine with the single Dominator deal. At a similar weight thet would run about the same. Holleys helped my starting line consistency. But overall they are not a bunch quicker than the Eddy's. A few racers in N/SS are running tunnel rams in as well. I haven't seen a Indy -1 headed combo any quicker than my 440-25 stuff either. Duell, Dechicho both have run tunnel rams. Last week I met with Tom Ghent. He was the first to try welding dams in the 440-25. After talking to him that was on a application that used a flat plate for the intake lid for hood clearance. He admited that using the standard lid there may be no improvement. Mine is not modified.While I don't like the idea of moving away from the Indy 440-25 intake with the dual eddy 750's, will there be a measurable performance gain by switching to a manifold like the Edelbrock Super Victor and single 1000cfm carb? I am trying to maximize the performance of the combo I have.
I'm "out of the game" for now, but I do still have the 572 and it is about 80% parts complete, and one glorious day I'll have something to drop it in.Thanks all. I will stick with the 440-25 and look into a cam swap later this spring.
Maxwedge sized intakes used to be pretty few, and far between. Lots more common now. I have three, and possibly another that might be big enough to open up to max size.(M1, dominator pad). Pretty sure the winner of my bunch will be the dominator pad SuperVictor.I'm "out of the game" for now, but I do still have the 572 and it is about 80% parts complete, and one glorious day I'll have something to drop it in.
I'm mentioning that because now a 6bbl is not "necessary" and I really REALLY like what Doug did with his ModMan, but I also REALLY like the look and "mystique" of the 440-25...
Whatever intake I get will need MaxWedge ports for the TF 270s
