Purdy.....impressive too. What will it be used for?Took a couple hrs to snake the coil thru, but finally finished.
For Ham radio. It is a loading coil to make the 80M vertical electrically longer to work on 160M. The coil adds about 45' of length in 12" of coil. I finally burned up the 160M relay in the tuner running power and using the tuner to match the antenna for the radio, so now I am doing it the correct way. Got a new relay and relay board coming to fix the tuner, so I don't burn it up again.Purdy.....impressive too. What will it be used for?
New kegerator? Awesome, I’ll be right over, you know, to make sure its “working right”?Took a couple hrs to snake the coil thru, but finally finished.
Finished up the front courtyard pavers.
Had to pour a curb to get this walkway right. Still sweeping sand into the joints
From the garage.
I used more of the large pavers than anticipated because of the curved edge where I avoided using the smaller ones. As a result I came up 6 pavers short and had to fgo back for more (I bought 2,440 initially). So what do I do? Tear out some more. I decided to pave off the driveway and around the garbage cans. Back to work!
Final talley:
40,000 lbs of rock
17,000 lbs of sand
33,000 lbs of pavers
90.000 lbs total
I've bought a few lately but nothing much to brag about except for a .22 bolt action and a .22 automatic pistol....but buying from an individual where that's still pretty easy and before they kill that market by making it illegal or something.Well, when i got down to the 180 pound weight, from 230 pounds, when i started dieting to loose weight, i promised myself, when i did it, I would go and purchase myself a new handgun, for me, on the accomplishment in loosing 50 pounds off this old mans body.
Haven't purchased any kind of firearm in probably 15+ years.
I'm one pound away from my goal of 180, at 181.
So today, i went around the Sacramento, CA. area, at some of the gun shops that are here around town.
I want to buy one of those CZ (Czechoslovakia Republic) guns, after doing my research on them, being a quality firearm, and accurate.
Boy, all the BS that one has to go through, now a days, out here in Commiefornia, in purchasing a firearm.
I can remember back in 1980, when i discharged out of the Air Force, all that was needed was my DD-214, discharge paper.
Not any more.
Times have sure changed.
Jim V.
hemi71x
71 is when I started having harder times....hope you don't!!I pulled lower control arms off a 69 Dart at the local Pick-N-Pull, down the street from me, at their 25% off sale, that's going on.
I haven't pulled LCA's in years, and now that i'm 51 pounds lighter, getting under a car, and sides of a car, is a whole lot easier, for this 70 year old guy.
Ya, me too.71 is when I started having harder times....hope you don't!!
