33 IMP
- 4:11 PM
- Dec 21, 2017
- taxifornia,soon 2b Arizona.
Good to hear. I don't yet know how nose heavy I am, but I would guess 60/40. I'm gonna do what I can to try for 55/45.With no ballast mine is 310 lbs nose heavy. It hooks really well. We move 80lbs in and out of the trunk all the time. Doesn't bother the 60 ft at all. However when we reduce timing from 35 to 27 along with weight in the rear 100-200 lbs to run index (from 9.0x to 9.25). It kills the 60 ft especially with high water grains. Believe it or not part of that is tire spin. It just doesn't hit the tire hard enough to plant it. It's an ongoing battle. Going to try something other than timing to slow it for index next year. When we run it flat out the 60ft varies less than .00x. Until late evening when it the dew point drops. Even then seldom more than .01 in 60ft from pass to pass. So you can make it work nose heavy. It just takes some different settings.
