- 3:54 AM
- May 27, 2015
- Gaston South Carolina
Steering box ?????? Any measurements you need from me just let me know.
Thanks Charles. Shot of my steering box. I assume it’s original but I am no expert. I doubt these get replaced very often I would bet its original.Steering box ?????? Any measurements you need from me just let me know.
Uhhh...You aren't too familiar with bump steer and geometry, are you?If I could move it rearward by 1/2 inch I would be set!
No I’ve never messed with the column other than the coupler. Sounds easy enough. So will there be a lot of resistance in the separation? What holds them in place just the plastic sheer pins?Uhhh...You aren't too familiar with bump steer and geometry, are you?
You are making this much harder than necessary. Pull the column and extend the intersection of the inner and outer shafts. You can have this out, extended and back in within an hour.
Thanks for the encouragement, KD! With your help and the rest of the team here I know I’ll get this sorted out!By "geometry", I mean the relationship between the placement of the steering box, Pitman arm, the sweep of it in relation to the idler arm and center link, the tie rod sleeves and lower ball joint steering arms. All of that needs to be in reasonably close alignment for the car to steer right and track straight, especially on bumpy roads.
Moving the steering box rearward by even 1/2" can have negative effects on how it feels.
You did bodywork and painted the car. You've done other things. Even if you're not experienced with everything, it is clear that you have the drive to jump in and do things. That is respectable. You can do this, it is well within your skill set.
What about the bearing in the top of the column? Will that come out as well with the shaft?You really don't need to take it apart. Remove the column, tap steering shaft out (towards the box if on the car). Reinstall.
No. The steering wheel will hold the upper portion tight provided you have the wheel retaining nut on. Also, the shaft is two pieces. The upper shaft should stay put, lower should extend. If you go thru Dadsbee's restoration post he goes into great detail about how the upper and lower shafts are connected.What about the bearing in the top of the column? Will that come out as well with the shaft?
1970 Sport SatelliteNot sure what you are working on but, 68/69 steering shafts are 41.4" (PS), 44.5" (Non PS) You can get a very, very rough measurement while still in the car.
My notes say they are the same. This might be helpful....1970 Sport Satellite
Wow awesome Charles! Thanks so much for taking the time to help me with this!This is a steering column fully assembled out of a 70 Superbird. Here are the measurements
The more you blow them up on the forum the more blurry they get. If you PM me a cell number I’ll be glad to text the pictures to you. Thanks Mike. Or Charles, I go by Mike.Either one is good.Wow awesome Charles! Thanks so much for taking the time to help me with this!
