That’s what I’m talking about also.Padam,
Yes I was referring to a HSS drill bit. They are one piece HSS, shank is same hardness as the tip.
They have pills for that noware only hard for about an inch and a half.
The Damned pills don't work anymore!!!!! Impunity, or something like that!
HAPPY THANKSGIVING EVERYONE!
Oh wait, are you using the yellow or pink bit with that playskool drill?Sigh.
All the HSS drill bits I have seen have a shiny finish, not dull like in post #23. I am not sure what the material is in bits that have a dark colour, but they are a softer steel than HSS, will not drill tough materials like HSS will & they become blunt more quickly. The dark colour I presume is some sort of heat/hardening treatment. These drills are cheaper than HSS...for a reason.
A HSS drill is the same hardness throughout it's length. I have broken these drills, refaced the tip on the remaining section......& drilled holes with what is left. And I have done it many times....
If you have a lathe you must have some tool steel drill rod around. Take a 6” long piece. Heat one end cherry red about an inch back and quench it. Check the hardness on each end. One end should be hard and the other much softer.Think about this & then go and play with your toy fire engine:
One of my most used lathe tools is made of 1/2" square HSS. It is about about 1.5" long. Same material as HSS drill bits. It has been cut from a 8" length...That works because the material is the same hardness throughout.
My only intent responding to this thread was to provide some information on how steel is hardened.Think about this & then go and play with your toy fire engine:
