Question about TTI 426 hemi Headers
dan juhasz
10:25 PM
Whiting NJ
I was thinking about buying TTI 426 Hemi Headers 2 1/8 primary tube. Car is a factory 67 GTX 426 4 speed. I was reading through all the footnotes provided in their install adjustments. The one sticky point is a reference to working with 143 tooth flywheel. 66/67 Hemi cars are 172 tooth flywheel. Of course I called TTI and the older gentlemen I got on the phone from tech said he couldn't give me a concrete answer. He said most people switch to the smaller bellhousing and flywheel. I don't want the extra expense of bellhousing, flywheel, clutch just to have headers. RobbMC makes a mini starter for the direct drive bellhousing.
So has any member bought and installed TTI hemi headers on a 66/67 with the 172 tooth factory flywheel ? I don't want to buy these and have to start hammering tubes for clearance issue.
no help here , but I`d be very wary of robmc peformance , he wont stand behind the products he sells ...
I bought a set of roller rockers off of him , the exhaust rockers weren`t even machined for keeper clearance , and guess what , he wouldnt make them good ! As far as I`m concerned he`s apiece of **** !!!
only purchases I've made from him are his offset dowel pins for bell housing and one of his starters. Those parts were fine. Unless I'm mistaken he is the only person that makes a starter to replace the direct drive starters.
I
I`ve got a summit mopar starter on my 505 , best yet , no problems...
I have tti's on my '69, but, the bellhousing is a '68. I have counted the teeth, can't remember, 143? Dakota starter, tti's are 2 1/4".
Yes yours would be a 143 tooth , the 66 and 67 are saddled with that 172 tooth monster. They won’t guarantee a fit. If I have to switch because of the headers I would need a new bell housing, flywheel, clutch, starter. I’m just going to stay with the manifolds.
Not sure if this helps you but I bought a Hooker set off a 69 4 speed RR, big flywheel and direct drive starter, they fit well but tight in places he said, no dings in them. If fact I bought the headers, h-pipes and mufflers
68 and 69 also had same set up, it changed in 1970
I have to recant my bellhousing year, it's a '69 with the dual 3-speed/4-speed pattern, 143 tooth flywheel and 11" clutch.
1970 was first year for that bell 10-1/2” scalloped clutch 143 wheel reg reduction starter, 90% sure of that. I’ll check my engine manual.
I can get a part number off my bellhousing, Dan B told me that it was a '69. Was going to trade + for a scattershield, but going to keep it in case.
