Sniper EFI software issue
threewood
11:56 AM
SE NM
So I want to take a look at my most recent configuration file for my car. Loaded it onto the SD card, put it in my computer. Computer recognizes the drive as Holley. I can't open any configuration file! My Holley desk top download can't find it. And if I try and open it, it won't find the Holley software and asks what app I want to use.
Any tips? Holley software is a step up from ms dos.
Sounds like your computer is not updated or the card is corrupt.
I found it. The user interface for their software is crap.
The reason I was checking the tune was because occassionally the car would hang at a higher rpm but would go back to normal idle with a blip of the throttle.
I checked the throttle cable, no binding or hanging up. I pulled the distributor and rebuilt, re greased the mechanical advance. No issue.
I was able to hang it a few times in the shop and the culprit ended up being the secondary arm sticking a bit open. I hosed down the link and the blades with Seafoam and it seems all is right again.
About 90% of software problems are actually hardware.
Yep. When it would hang, the tps was at 0% and the ias was at 0%. That secondary throttle link is slotted so it being open didn't hold open the primary throttle.
