Tex013
lots of areas for thought . I guess it depends as usual on how far is far enough . My 68 Satellite is about 3780lb with me on the start line . The World block added 90lb over factory RB block. I have fibreglass bonnet and front bumper , front and rear brackets are cut down . Usual aluminium stuff in engine bay , no power steer ot power brakes . Only simple weight reduction would be to remove heater and front bench seat . Though as a regular street car a demister is good . No rear seat as it now has a cro moly rollbar , weight of bar was similar to seat .Thin marine carpet no underlay . Aluminium wheels and radial slicks , PBRs are 34ish lb each . Street exhaust to diff with 3"pipe and aerochambers .
I guess I could bore block to 4.5 that should drop a few pounds and add HP
I do have 4 w discs , not wilwood , so no big weight loss but way better braking @ 130 . Gave up on rear 10"drums @ 125 .
oh yeah Im a skinny guy maybe 140lb give or take on a big day , that helps for sure .
Tex
.I do have 4 w discs , not wilwood , so no big weight loss but way better braking @ 130 . Gave up on rear 10"drums @ 125 .
Tex
