fullmetaljacket
- 11:07 AM
- Oct 15, 2010
- Brooklyn, New York
Going back to the front, I forgot to mention that if an electric pump out back is replacing the mechanical push rod unit up front on the motor, there's a savings there in that the weight is not necessarily removed, but relocated out back. The actual savings though minimal is the block off plate from Moroso and other manufactures that are stamped out of aluminum. The two fasteners were also replaced with aluminum types.
Did I weigh them, yes, but I can't find the numbers. In actuality, the factory mechanical pump is probably lighter than any electric unit and like I said, the weight is just being transferred rearward. A good thing.
