Huicho417
- 10:20 AM
- Sep 15, 2020
- San Antonio , Texas
I have some problems with my fuel gauge reading correctly, and have finally decided to take care of this annoying issue. It is an aftermarket sender and original fuel gauge. Knowing that the new senders do not really send correct ohm readings I added a meter match to help.
My issue is that after I calibrate the gauge with the meter match device. A full tank will only read at about 3/4 full. I do have a new grounding strap from sender to steel fuel line. But will add a grounding strap screwed to frame and see if that helps.
Here’s the question. My insulated connector that goes over the sender stud was very brittle and cracked. I replaced it with a ring connector with nut. Any chance this may be adding to the issue?
