WTB Wanted: spring steel washers for vent window handle
Richard Cranium
7:18 AM
New Hampster
Feedback: +29 / =0 / -0
As pictured below. Handle retaining pins needed also …. two of each.
Or, I’d take two complete junk lower vent window channels.
:thumbsup:
I'll bet you can buy spring washers from the local hardware store. Perhaps pins too. Look at nails, they are soft enough to peen in place.
Thanks, but I checked the local Ace hardware store and no go.
I've got all that stuff...are you still in need? I'm stripping down a set of wasted vent window assemblys
I believe the vent window pivot shaft is 5/16 which is .312... The hole in these wave washers is .330
The pin is a roll pin... I don't know the dimensions...
