Paul_G
- 2:12 PM
- Dec 24, 2013
- Surprise, Arizona
The trans was rebuilt last year by a reputable shop here in Phoenix. He does a lot heavy duty diesel trans work. He told me he put a lot of the heavy duty diesel parts in my 46RH along with a shift kit.
The problem from the get go is getting the trans to shift at WOT, both second and third gears. It has a Lokar shift cable I have adjusted 10 ways from Sunday. No matter the adjustment, It will run straight to the rev limiter at 5500 and never shift.
First cable adjustment I did after installing the trans was to have the throttle lever at max travel with the carb at WOT, driving normally at normal neighborhood speeds, my 1 to2 shift was at 30 MPH, 2 to 3 at 45 MPH. I hade to adjust the cable back quite a bit to get my shift points down to a reasonable 1 to 2 around 10MPH and 2 to 3 around 20. Even then it would not upshift at WOT. Next, I adjusted the cable back even further where my 1/2 shift was around 6 MPH and 2/3 around 12. Still no upshift at WOT.
I have the OD off during all this testing.
My trans guy thinks the problem is with my cable, the adjustment, and the length of the throttle arm on the trans. What do you guys think?
I have a Bouchillon cable kit coming, $325.
Edit: the drive train
Stock 440
F1 Procharger making 6lb's boost
46RH
4.10 Dana
26" tire
Stock 440
46RH
4.10 Dana
26" tire
