Can an MSD blaster coil be used with a point ignition system?
sad to say the msd is a dog
Am I lucky or just sexy?I’ve been using the epoxy filled MSD 8222 blaster high vibration coil for a couple of years on my point ignition system. No oil to worry about.
Where are the grammar police when we need them.I've only has a couple of coils fail in all my years and never had an Accel or MSD coil crap out on me.
There are some coils that are supposed to me mounted UPright. Even those I've mounted upright and horizontal and haven't has failures.
WHY WOULD YOU WANT TO?? YOU SHOULD ABSOLUTELY NOT MIX MATCH IGNITION SYSTEM COMPONENTS AS THAT WILL LEAD TO OPERATING SYSTEM DIFFICULTIES. The coil could draw too much amperage causing premature point failure or ignition switch damage and must be complimented with the correct ballast resistor ohm-age to match the coil.......in spite of what your buddies have told you. Do your own research......just my opinion of course....ask @HALLIFAXHOPS if you prefer....Can an MSD blaster coil be used with a point ignition system?
This is exactly the reason I went with the Accel 8140. 1.4Ω primary resistance with a 0.5Ω ballast resistor. About as close to stock specs as possible.WHY WOULD YOU WANT TO?? YOU SHOULD ABSOLUTELY NOT MIX MATCH IGNITION SYSTEM COMPONENTS AS THAT WILL LEAD TO OPERATING SYSTEM DIFFICULTIES. The coil could draw too much amperage causing premature point failure or ignition switch damage and must be complimented with the correct ballast resistor ohm-age to match the coil.......in spite of what your buddies have told you. Do your own research......just my opinion of course....ask @HALLIFAXHOPS if you prefer....
BOB RENTON
Thanks, I agree.WHY WOULD YOU WANT TO?? YOU SHOULD ABSOLUTELY NOT MIX MATCH IGNITION SYSTEM COMPONENTS AS THAT WILL LEAD TO OPERATING SYSTEM DIFFICULTIES. The coil could draw too much amperage causing premature point failure or ignition switch damage and must be complimented with the correct ballast resistor ohm-age to match the coil.......in spite of what your buddies have told you. Do your own research......just my opinion of course....ask @HALLIFAXHOPS if you prefer....
BOB RENTON
Snapped big time.Where are the grammar police when we need them.
There are some coils that are supposed to me mounted UPright. Even those I've mounted upright and horizontal and haven't had failures. The only ones I had go bad were parts store generics.
Okay, I know that I'm not looking too sexy here so I must just be lucky.
I "agreed" on all three statements. Especially the lastAm I lucky or just sexy?
