- 4:08 AM
- Apr 13, 2012
- Granite Bay CA
In the engine bay may make even more sense. I have to run wires through the firewall anyway.
It’s your guys call but if you’re going to run the heater hoses through the wheel well anyways why not just put the valve there also? I put mine exactly where the Vintage directions said to and ran that wire along with the AC compressor wire with the heater hoses and through the grommets in the firewall and then silicone the grommets as stated per directions.I'd like the water valve in the wheel well or engine compartment. I don't want any risk of future leaks in the interior cabin.
I edited the last post to reflect that the VA directions may be the only way to make it work and look decent.Looks like if we don't want to have crowded under dash lines and hoses (as in if we mounted directly to the firewall instead), then the only other option is through the alignment access hole per the vintage air default instructions. Can you make that work and still have the lines hug high and tight in the fender well as per your original plan?
Here’s the only pic I could muster up of mine. I still plan on doing some adjustments on shortening up some of the lines and changing the clamps out on the heater hoses.I couldn't find many pictures of Vintage Air installations going through the alignment cam hole but here are a few, the first three of a '71 Road Runner by Mopar Jack.
This setup has both the suction and discharge lines going to the passenger side so it is slightly more crowded than what I'll be doing but it does give an impression of what I'll be dealing with.
LOOK at the wide open area back here though!
Even with my own car, I had to set aside the notion of how I loved an uncluttered engine bay. The additional components of the A/C system don't add any beauty but they are a necessary change to make the cars more comfortable to drive in warm/hot weather.
Is it all synthetic?Probably the exact same contents but with a bunch of additional taxes and fees that do nothing to help or hurt the environment.
Ha ha...Thanks Greg. From here on out with this AC line/hose install, I'm fine with whatever you decide. Nice progress.
