71' B'body Headers
kma9176
1:24 AM
Surrey
Anyone reccomend which long tube headers are best for a 340 stroker in a 71'Satellite ? Have Headmans at the moment but will need changing soon - I was told the Doug Thorley headers were best but they dont do them for a small block in a B'body??
There was a post talking about this a week or two ago. It seems like the main header concern for small blocks was ground clearance on the driver’s side. Many/most have 3 pipes hanging very low. It’s been a while since I ran small blocks, but that sounds correct
Here are Dougs headers on my small block that is in my 71 Runner.
You can see in the first photo that the collector is a little lower than the bottom of the engine K-member.
They look great - whats the clearance like 2nd bolt back on the drivers side ? and do you know how far past the rear engine plate the collector flange sits ?(just so I know how much modifying I'm up for)
Kind regards
Kev
Kma9176 - I used the standard stud setup on the outer holes.
On all of the inner holes I used a 5/16-18UNC x 2" long stainless set screw with standard size ny-lok nuts.
No need for any special header bolts.
The second nut back on the drivers side along with the second nut from the front can be tightened with a open end wrench.
Not sure what you mean by 'rear engine plate'.
Here's a picture from the underside showing the collectors in place.
Thats great info thankyou rear of engine plate? Just the rear part of the engine where the Trans bell housing would bolt to (I was just tring to think of a reference point?)
YY1 - I'll have to get a photo of the oil filter setup.
That filter was on it when it was on the dyno along with dyno headers.
I hope it comes off....:praying:
I picked up a set of ceramic coated Flowtech long tube headers at a swap meet. Nice heavy flanges. Ran them on my LA360 and then my 5.9 magnum with zero issues. I have power steering and they also have plenty of ground clearance.
I'd think so. but you can always get the 90* oil filter adapter
WileERobby - no 90* adapter for me, they can be restrictive.
I took a couple of close up photos last night.
It's pretty close.
When it comes time to fire up the engine I'll put a new smaller one on.
So, I looked at the small block Flowtech headers on Summit.
They sure look to me like they go below the steering.
Can anyone confirm or deny?
I am VERY impressed with their big block headers, especially for the price.
They may be one of those "best kept secrets".
like I said in my previous post, I purchased my headers at a swap meet and from all of the research I have done I am 95% sure they are Flowtech headers. They fit great with no clearance isss, thick straight flanges and no leaks with remflex gaskets. I have had the same headers on both my LA 360 and my current Magnum 5.9 in my 72 Satty with AC. My car is currently on a lift so i dont have great pictures but i have never bottomed out. Currently using a straight full sized oil filter. FWIW the guy purchased them from said they would not fit in his A body and did some hammer work on the primary pipes but they would not have been necessary in my case.
So they are below the steering link, then?
Your link pic looks like they're not, but the pic of your car looks like they are.
The link pic also doesn't look like the same design.
Shows driver's side 4 tubes in a square config.
Pic on car shows three on the bottom.
