- 11:56 PM
- Jan 14, 2009
- Shoreline, Washington
For an original 1970 electronically regulated charging system, it will be a round back dual isolated field alternator. All it takes to get a full field voltage number as described is a short to ground on the green field wire running from the VR to the alternator or a brush with insulators not installed correctly, shorted to the case to put the alternator in full field. You can throw as many VRs at it you like, won’t change a thing.
