- 5:44 PM
- Jan 11, 2022
- Fredericksburg, VA
I have been working on figuring out this fuel leak issue that I had a while back. Got some advice, replaced all the lines and reinstalled the fuel pump on the car. Should have paid closer attention because I don't think I dealt with the push rod correctly. I pushed it up in there, but I had a suspicion that I let it slip back down when installing the fuel pump. When trying to start the car, I noted that the pump did not appear to be pump any fuel through so I assumed I had screwed up with the push rod. When I originally took the fuel pump off and removed the cap, the push rod slid right out. However, today when I removed the fuel pump, the push rod stayed just like you see in these pictures. It free spins, but I will not slide up or down. Side note: when I originally removed the pump and push rod, we measured the push rod with a caliper and it as within spec (in fact it looks almost new). Even when I tried cranking the car it did not move up or down (possibly because it has slid too far down to make contact with the cam). The bigger issue is why this push rod may be hung up and won't slide out. I would appreciate any thoughts, recommendations or advice people may have.
As an aside, I want to thank FBBO member @Dragon Slayer who has been especially helpful throughout this process.
