Cheapsunglasses
In Rust We Trust!
- 8:02 AM
- Dec 21, 2021
- Miserable Smells TX
Progress is progress no matter how much it it is
I would love it if the stock glove box and fuse panel location can be kept as-is. Thanks for trying to make that happen.The tape starts out at 5/16" and then is squished a bit in the roll. You can see where it flattens out slightly here:
Once compressed, at best it compresses to 3/16". I could pull the firewall plate and put actual gel/liquid sealant on it if you prefer. As it is, it sits close enough to look good. Your call. I used this because it was free and because I had it here already.
If so, I think I'll be able to keep the stock glove box liner.
It mounts windshields and back glass without he windows ever moving... I think it'll be okay...3/16" seems a bit thick to me, but it's already in. At first I was a bit worried that it won't retain it's strength to hold the plate and accessories vertically over time with heat and vibration since it's vertical and doesn't have the benefit of gravity to keep it in place, but there are also other screws fastening it to the firewall, so it should be ok.
yes, but like I was saying, those are both angled (as opposed to being vertical) and have the added benefit of gravity and are not exposed to under hood higher temps.It mounts windshields and back glass without he windows ever moving... I think it'll be okay...
I used the stuff that Vintage Air supplied. The duct hoses fit their adapters and were smaller than the OEM stuff. There will be some spare parts here you may want to sell to recoup some money. I know that I would. I love free cash.Wait - we need photos of the ECM, Ballast resistor and voltage regulator re-mounted to the firewall plate...
And the center dash vent. I already had the dual center dash vent, but I also provided an underdash plastic piece that had a metal tab to secure it. Was that used? How was the center vent connected to the hose?
Even though the A/C is not charged yet, the heater should still work. I'm hoping to hear that you are able to test heater function that it turns on and blows hot as intended![]()
