- 7:52 PM
- Oct 16, 2013
- Kiel Germany (back again)
Today was a bit of a disastrous day for me. Yesterday, I pulled the fuel sending unit and discovered that is was a junk Chinese one that had replace the factory original. I tested it and realized it was a hopeless cause as the readings were vastly different than what they should be. I looked at the sender seal that was in the tank and figured I would install my new DMT one as that is best practice.
I have a proper tool, so no issues to reinstall. I did make a mistake though and did not lube up the lock ring. Fatal error.
It is hard to see there due to the rear end, but I felt it slide right back to the lock position. I figured for now, I will just live with the crappy sending unit unit I can find a good used or NOS factory original.
The cars rear end was up on ramps. I put 5 gallons back into the tank from my spare fuel container. I knew that it would take the fuel level above the sender seal. I left the car 24 hours to make sure there were no leaks. When I came back to it this morning, no sign of any leaks. I decided to go to the gas station and fill her up and make 100% sure that all was well.
I started to fill her up watching for leaks and there were none. Just as I got the 19 gallons into the tank, fuel started to pour out of the sending unit seal. This is the worst possible situation. I am at the gas station and gas is pouring out all over the forecourt.
I was able to quickly siphon enough to get back down to a level where the leak stopped. After the dust had settled, I realized what happened.
The tank lock ring holder split, the full tank of gas built up enough pressure to push the seal out and the result was what you see above. Its the original tank, so I can say it's had a life.
So, I am asking advice from the members here, what should I do? I have to pull the tank no matter what. Is it a dumb idea to try and weld that? I am thinking that it would be stupid to not get a new tank. If I buy a new tank, what company is the best? I have had great dealings from Jeff from 521 Restorations in the past, but I want a quality tank, not a junk one.
All inputs welcome please.
