mavwreck
Have a torqueflite in my 67 coronet that I’m having shifting issues with.
1-2 shift under light throttle is right about where it’s supposed to be
1-2 shift WOT shifts too early (3900 rpm)
2-3 shift under light throttle is too high (3000 rpm)
2-3 shift WOT will not shift unless I slightly let off the throttle
2300 stall converter
440 engine with a cam
3.23 rear gear
Lokar cable kickdown
B&M z-gate shifter and it is adjusted correctly.
I took the pan off and there isn’t any clutch material in the bottom of it. The trans recently had new seals and gaskets installed. Could it be a band adjustment? Kickdown adjusted wrong? Clutches destroyed? Valve body screwed? Line pressure? I’m not much of a transmission guy so I don’t even know where to start. PLEASE HELP!
3.23 rear gear
