WTB Looking for a Dual Carb Choke Cable, also know as the Max Wedge Choke Cable
John Keyburn
5:32 AM
Bucks County, PA
Feedback: 1 / 0 / 0
Looking for the 6'9" Max Wedge Dual Choke Cable
Hello FBBO friends,
This cable seems to be sold out everywhere I know to look.
Im hoping a member here has one they are willing to part with, new reproduction or used is OK
Seen here
Can someone post a scan of the drill templates for the Choke cable hole in the firewall. Looking for accurate location to drill as well as the size of hole if not listed on the template.
Also, it looks like for 1962 Plymouths at least the dash hole is both farther away from the standard Brake release and headlight positions as well as a bit LOWER than those factory knobs.
Also, While I'm waiting on actually finding a correct Repo (or Original) cable(s) kit I've decided to try to make something using two 96" Choke cables for a garden tractor/ go kart.
Going to try to "plumb" them to the cigarette lighter spot.
(Inspiration from this video: (rats cannot find> )
Also-Also... Who knows where I can find the little pivoting anchor's that attach to the choke arm of the card that you cinch down around the center choke cable core. I have looked and cannot find.
(Ordered 2 of these From Amazon, going to see if I can combine them into one on the "Pull" end)
https://a.co/d/fwvcxDM
KK, Thanks for the ref pic. What's Odd is that my Plymouth Savoy(orig 318 car) has the speedometer hole and grommet exactly in the location the Choke cable is at in both the photo above as well as the MWDCC Instructions template. I even printed the template from this post <<Choke cable Grommet Max Wedge>> and held it up to double check.
Here you go …crossram do sell just the grommet.
Real MW car
