Roof gutter seam sealer removal
c.moo
1:41 PM
tennessee
This is on a 63 b body , got all the seam sealer off the whole car except in the roof gutters , this isn't coming off like the rest of it did , try heat gun , no go , wire wheel . putty knife ,razor knife , screwdriver takes forever and still can't get it all , it's different seam sealer then what was on other places on the car. Damn good stuff what ever it is ! What is the best quickest way to remove it . Thanks
I used a chisel to go straight down and break it loose along the very outer edge of the roof gutter on a 66 b body. After that i was able to chip it out with a screwdriver. Even doing that, there were still little bits and pieces left but not much. All the cracks in mine made it easier to get out but that stuff still held on good.
I use a heavy duty bent pick from Tractor Central. Not a fun job by any means.
Get all you can with a dull screw driver, little bend up on the blade. Careful of the seams.
After that your air drill and a course steel wire brush bit.
No easy way I'm afraid, elbow grease, beers and some music...friends would be helpful. All the hand tools mentioned above would help get it done. I've known guys to use an air chisel but I wouldn't recommend it.
If it's that tough why remove it? Scuff, re-paint.
Not going do half *** , what seam that I did get off was rust underneath ,not much but still rust , got car on rotisserie , all metal work is done , all is left is getting the seam sealer out of the gutters and cleaned before putting on epoxy primer on whole car , been working on this thing for 4 years now not going to cut corners now .
This will probably work, wear gloves and eye protection. I've found them in 2" and 3" diameter. Turn them over when they get a little dull, or find some with a fixed arbor and use a reversible drill.
Mule Skinner Encapsulated Brush
Who said anything about half ***? You never mentioned what kind of shape it was in to begin with. If it was all intact, you f@cked up by tearing into it. If it was just cracked, you could have skim coated, prep and painted as Elk says. If it was all chunked up and coming apart then you're doing the correct thing to clean it up. As others have said, not a fun project.
No I didn't mention what kind of shape it was in , I ask how to removed it , how could I f@cked up tearing into it ,stuff is over 61 years old needed to be out of there , didn't see in your comment how to removed it .
Up date got it out of there , used different flavors of round wire wheel brushes and razor knife and pick with hook end . Was expecting the worst when sealer was removed , only bad rust was on the a -pillars , nothing sand paper and wire brush won't take care of . Thanks everybody and if I offended anybody didn't mean to.
My guess based on your response is that it was all intact and you tore into it anyway. Whatever. Glad you got it all out of there. Sounds like it will be a top notch resto.
Going the extra mile always pays off.
They still sell the Seam Sealer for the Rain Gutters that you are removing anything else won’t work over time the other stuff Cracks over time.Get the proper Sealer for Rain Gutters it’s in a tube it flows nicely!!!!!nOh and you have to buy the mixing Applicator gun! At the paint Supply Supply Store.
I used one of those Pic style tool and muscle! You could heat t a little just stay from the Roof sheet metal. I don’t believe I would use a torch but rather a heat gun!
Once started try to peel off the rain gutter sealer! I used a bent Pic tool!
