MaxWedgeWagon
Made great progress and then the project came to stall...
Installed dakota digital gauges, wired up the engine and 6al MSD box. Discovered the MSD box was broken. Redneck wired up the cheap Chinese ready to run distributor to get it started. Engine Fires right up every single time which is super cool! Sounds mean as hell, unfortunately quiet mode is still loud so i ordered another set of flow fx mufflers and will run the exhaust out the back. Then we tried to move it...
Transmission has no line pressure. With the tires in the air it has all forward gears except park. I got the transmission from an older gentleman who restores b bodies and removed this trans that was running for one that was number matching. I failed to ask how long the trans had been sitting before purchasing. Turns out 8 Years. It's Junk. Definitely a huge loss. Not sure what the plan is. Not too thrilled of the idea of rolling the dice on another used transmission.
We managed to push it around to the alignment rack and boy do these things suck to align. I used antisieze on all my adjusters and they still required alot of strength to turn the adjusters. Not to mention we had to pull the wheels and re-calibrate each adjustment. Overall a stout alignment. Id prefer more caster for high speed stability, but I also wanted 1.5-2 degrees of negative camber to help out in the corners. My M3 which was a handling machine and great on the highway was over 7 degrees of caster and 2.5 degrees of negative camber. I like them set up pretty aggressive.
We had a shop party for customers and the wagon was a crowd favorite. Definitely made me feel better about a junk transmission. I will find away to get some exhuast videos uploaded later this weekend.
