Have a very unusual issue happening in my house. When we bought the house, the hot water would scald you if you weren't careful. One day I was home working and heard a really wierd girgling sound. It was coming from the water softener. I turned on a faucet and there was no water. Turns out the water main in front of our house broke and it was creating a backflow that sent the plastic filter media from the softener thruoughout the plumbing. After a few weeks of taking things apart and cleaning them, I finally got all the faucets and toilets functioning when the hot water heater quit working. I bought a new electric water heater, I installed it myself. I hooked up the supply line and soldered it all, and I closed off the inlet valve that goes into the heater so I could turn the water supply on for my pita wife to use water for something. Damned if I didn't hear water coming through the hot water pipe that is supposed to be the outlet from the tank. Again, this was not connected, so it was backflowing cold water TOWARDS the hot water heater. I had to shut off the water until I had it connected. I thought it was wierd but didn't give it another thought until we realized we don't get really hot water anymore, unless you flush a toilet. It still comes out pretty warm but in our hall bath that has a mixing valve for the fawcet, it is lukewarm and wife and daughter freeze in the shower. All other faucets have a separate hot and cold handle. I'm at a loss as to what happened. Again, if you flush a toilet, the water will scald you coming out of the hot side everywhere but their tub faucet.
Sorry for the rambling post but this is super irritating, she can't even use the dishwasher because the water isn't hot enough to clean the dishes. Same with the laundry.
Thanks in advance. It seems like the cold water is tainting the hot water system, and yes, I have the inlet and outlets correct on the heater.
