 - 8:26 AM
 - Apr 13, 2012
 - Granite Bay CA
I am armchair engineer. My scale is analog, not scientific like Renton.
			I remember Dwight from years ago when I was installing the CAA in the Coronet. He was a tremendous help, and patient with my have-no-idea-what-I'm-doing questions.I'll find out tomorrow. Their guy, Dwight, always seems eager to help.
Not sure which adjustable A/C t-stat that guy used, but Vintage Air offers one that has good reviews on Summit:KD - since you mention your compressor cycling on and off, I did some digging online. I came across another thread where a guy was having the same problem you describe with a CAA system. Classic Auto Air had him change the thermostat 3 different times, but he kept getting the same issue. He finally decided to buy a solid state programmable thermostat and it solved his issue.
The system came with a thermostat as you describe but it did not work out of the box. CAA sent a new thermostat but it did the same thing. ( cycled on/off every few sec)
So I purchased a solid state electronic heat/AC thermostat with a digital readout for temp and installed it. I set the output for 34 degrees off and 46 degrees on which controls the compressor.
The AC works great and I am in the process of refining the system operation.
Classic Auto Air cycling too often
it didn't say in the thread.Interesting read. I wonder where the guy sourced the programmable t-stat from. Since I'm not there yet on the cars, it would be worthwhile to have that in my info stash for when the time comes.
The high pressure side reads real low compared to the chart. What are CAA specs for the high side?
It continues to be a pain in the ***.This system has been a pain in the ***.
On my 70 Charger back in the 70's I was able to do a cam swap without cracking a single fitting... Pulled the radiator & unbolted the condenser which allowed just enough room to sneak the cam out & back in... Not saying it's easy, it's a PITA but it can be done...It continues to be a pain in the ***.
I don't know where the fault lies but this system is not consistent. I just tried it today and it is blowing barely cooler than the 107 degrees it was outside.
No, I didn't put the gauges on it. I was pissed off and decided to walk away from it. If all I cared about was a heater and defroster, this setup would be great. I don't want to blame the system though. It is is more likely to be a leak in some area that I haven't been able to determine. This is where proper leak detection will make the difference. I might take it to the shop just for that. It is $90 and it will probably solve the problem.
Earlier this year I did the Vintage Air system in Dwayne's car.....
I routed the #6 line in a better way than I did in my car. This may inspire me to reroute mine to hide better.
I have considered a cam swap too which means pulling the radiator and condensor, opening the system and losing everything inside.
Son of a beeeeech.
