- 7:07 PM
- Apr 13, 2012
- Granite Bay CA
Great read KD!! I enjoyed following along your adventures as I have been down this path too.
It is a learning experience but has turned out to be simpler than I thought.
As for centering the steering wheel by turning the tie rod ends, just might be worth mentioning that your suspension gain can change when you do. And with a differing length of tie rod, you can see where the camber/toe change is different when you adjust those tie rod sleeves. Not the end of the world, just something to be aware of if you have to spin them a bunch.
Dwayne (@68 Sport Satellite) expressed concern about the dangers of steering component failure like he almost had with his car due to improper service he received at a second rate shop. Maybe this was what he meant? I aimed for equal lengths in the tie rod assemblies when I put this one together. I was as close as I could get and am still at 12 1/2” left and 12” right when I measured center to center on the tie rod assemblies. This Borgeson steering box has to be installed centered of its left to right travel. The wheel needs to be centered. That will limit what you can do with the tie rod lengths. Jigsaw has different lengths for the tie rod assemblies too.
Anyhow, thx for your excellent documentary and great pics. Well done!!
Thank you for the kind words. This is one of the reasons that I enjoy these online forums…. The ability to share information.
Cheers.
