Dashpot
Turbobus
5:51 PM
Oklahoma
My Holley dashpot isn’t strong enough to increase the idle rpm when a/c is on even when the throttle return spring is removed, it’ll work if I slightly depress the accelerator but I would like a dashpot with a bit more power, is it a pipe dream or does someone make a more powerful dashpot? Or do I need to some other adjustments?
The dashpot is a "shock absorber" for the throttle closing. It slows closing to prevent stalling and (I think for emissions). If you are referring to the idle solenoid, that is designed to increase idle rpm to carry the extra load of the A/C compressor.
Mike, yes am referring to the solenoid that increases idle rpm when the compressor is energized (as long as pressure requirements are met within the system).
Does the pin in the solenoid stroke easily by hand? Will it snap out with 12 volts applied? Is the wire supplying battery voltage?
I don't recall ever seeing an idle kick up solenoid that will activate without tapping the accelerator. Just the nature of the beast...
Yep, I was afraid of that but thanks for your reply!
Yes to all! The holding power is great, it just doesn’t have that initial umph to move the throttle even without the return spring.
Kinda get the feeling that’s just the way it is. Thank you for your reply! If I find one that works, i’ll post it.
