- 10:26 PM
- Jan 31, 2018
- Caldwell, Idaho
I will open this pretty box after work.
I got water wetter also.
I see that barbed nipple on that tank I was talking about!
Why are you checking my nipple? LoLI see that barbed nipple on that tank I was talking about!
Because you only have one.... LOLWhy are you checking my nipple? LoL
There are kits to convert used freon tanks into air tanks. Almost free??Next project was to add on board air compressor mainly just to fill motorcycle tires since I ride allot. I had this viair to work with so made it work.
A tank would be nice no $ for that. I put a short hose whip on then just pop on a flex hose to reach what your working on.
It works for me.
I had same issue with wrong struts.Question for XJ guys, I can not keep my rear liftgate struts to stay on , bought new ones and still an issue ! Anyone have a good fix ?
I bought the crank (new), pistons, rings, & bearings from Scat. I reused the 4.0 rods. There are a few stroker combos that have worked; some using 4.0 rods, some 4.2 rods, different pistons, some with new crank, some with resurfaced 4.2 used stuff. Check out Jeep Strokers - HomepageI have been looking into doing a stroker for my TJ did you piece your self or buy a kit
Bruce
I bought mine at the dealership. A little more money, but work perfectly. The ones I saw at Oreilly's and NAPA had plastic ends on them as opposed to metal.I had same issue with wrong struts.
I will look up # that fits. I bought at oreileys.
