TorRed
- 1:04 PM
- Dec 12, 2023
- The Villages, Florida
Hi All,
I'm strongly considering a 'mostly' stock appearing rebuild of my 1970 Roadrunner (383, 727 Auto, 8.75 Rear) and have some questions for any of you that have taken that path. I already have a G/V overdrive. tight FTI 3000 stall converter for the trans and 4.10 gears for the rear. Not sure about the converter but pretty sure I'll go to a higher gear like 3.91, 3.73 or even 3.55 depending on where the engine's rpm range ends up. As for the motor I'm looking at either the 432 or 489 stroker kits from 440Source but not sure the larger kit will work with stock intake and exhaust? I'll go with either the TTI 2.5" or 3.0" manifold back H pipe exhaust but want to swap the Turbo mufflers for Dynomax UltraFlows. I have the original intake but have a larger 70/71 440 AVS 750cfm carb I'd like to use but again don't know if that's enough carb for the 489 c.i. stroker? I also have a Lunati hydraulic roller I'd like to use but once again it was bought for a higher HP build so don't know if I'm going to have to go milder? I know the 489 will tame it to a large degree so that has me leaning to the 489 for that and for the extra HP it would bring. I would greatly appreciate any and all opinions but especially those who've gone down this path before and have advice on pitfalls, what worked, etc. I've read some really good articles about these types of builds but would really value the opinions / experience of the forum.
Thanks in advance,
Jim
Thanks in advance,
Jim
