33 IMP
- 10:57 AM
- Dec 21, 2017
- taxifornia,soon 2b Arizona.
I don't like it. California is bent out of shape that I had my box truck here, so I need to move it to Arizona. That means I need something else to drive back with. I can hook my open trailer to the box, and drag my daily driver (about 3700 lbs) easily. But I don't wanna do that. It would leave my trailer stuck in Arizona, and I want it here for my California bracket car. (Racetrack is 15 miles away in Cali, 125 miles away in arizona)
The other thought, is to put my 2500hd on the trailer so I can bring the trailer back with it. It should BARELY fit on the trailer, and I know the box can pull it, BUT.....
the tires on the trailer are rated for 1875 lbs each, four of em. I'm pretty sure the trailer itself is around 1000 lbs, and I know the HD is around 6500, or maybe a bit more. ( I did use the trailer behind my 2500hd to tow my 454 dually to AZ, but I think it's around 5000 lbs.
Bottom line, I'm on the ragged edge, if not over , for load on my tires. Do I risk it, to save two commute trips from socal to AZ, or do I simply eat the expense and labor and carry the driver? (Roughly 250 miles thru California desert, one way.) I travel EARLY in the morning from Cali to AZ, 2am to 7am.
