Centerline
I have a tough one for you guys. I have an A904 torqueflight and I'm trying to identify the year of manufacture. The guy I purchased it from had it in a '67 Belevedere and decided to switch to a 4 speed. The numbers on the pan rail are 202729X 7381 6082. None of these numbers make sense. The first should be the casting number which identifies the make and model of the original car/truck and the second should be the julian date with the third set as the production number but I can't find these anywhere. The trans has a 27 spline input shaft so it should be '67 or later. With the X in the part number I'm wondering if it might be a factory replacement, but I don't really have a clue.
I'm getting ready to go through this trans and need to make sure I order the correct rebuild kit. Any help will be appreciated.
