mpro69rr
Hey guys, I have a 69 RR 383 4 speed with electronic pertronix distributor. I read here on the forum that the SS voltage regulator I have all run above 15v so I would like to replace it with an electronic voltage regulator which runs between 14.1v and 14.5v. I found the regulator and connector on Amazon (see links below). The connector has 2 wires, the green obviously goes to FLD, the blue goes to blue on the SS regulator, but this also has a blue with with tracer on it too. There is three wires that go to the SS regulator, how would I connect the connector which only has 2 wires? Would I connect the blue and blue with tracer to the blue wire on the harness? I want to get this right so I don't fry anything. The blue tracer wire on the SS regulator goes to ING, the other blue wire goes to the ballast correct? Anyone have a diagram to show how I would connect it? Thanks for the help!
ELECTRONIC REGULATOR
HARNESS
HARNESS
