just put together a 340 with a comp cam mild set up, break in went well. about 400 miles so far so good
I put one of these in my 78 truck with a 360 4 speed and put hooker headers and a 600 edelbrock carb in 2008 and it still runs good has a nice lope and lots of powerDown to my last part for my 70 charger sb engine. Looking at this. Its just a cruiser with pb and ac. Comp Cam 20-212-2 COMP Cams SK20-212-2 COMP Cams High Energy Cam and Lifter Kits | Summit Racing
Good 318 cam. Ran one in a Duster with a thermoquad, 340 exhaust manifolds, and dual exhaust. Was a 4-speed with 3.55 gears. Little screamer.looking at this cam should be good with all stock parts. Any thoughts? Summit Racing SUM-K6900 Summit Racing™ Classic Cam and Lifter Kits | Summit Racing
Do you remember if you changed the valve springs with this cam?Good 318 cam. Ran one in a Duster with a thermoquad, 340 exhaust manifolds, and dual exhaust. Was a 4-speed with 3.55 gears. Little screamer.
I did not. It was a low mileage engine from a 70 Challenger someone was putting a 6.1 in. I changed the cam, timing chain, water pump, otherwise the long block was stock.Do you remember if you changed the valve springs with this cam?
well f--k lifter failure today 1250 miles. pulling intake tomorrowjust put together a 340 with a comp cam mild set up, break in went well. about 400 miles so far so good
Hoping for the best for you, but prepare for the worst.well f--k lifter failure today 1250 miles. pulling intake tomorrow![]()
