Road Grabber
- 10:23 PM
- Apr 14, 2020
- Sarasota Florida/NY State
I have a 440 six pack build in a 70 Charger with the 240 Trickflow heads and would prefer to keep the HP manifolds.
I ran into some issues and would like to know if anyone has some experience with the install of these heads on 440s.
I tried to install champion plugs and ran into interference issues when the 13/16 hex rubbed against the aluminum casting and I couldn't keep the socket on long enough if I wanted to install the plugs all the way.
An engine builder installed the heads. I have to look for the paperwork if there is a factory recommendation. Next call Trickflow....
Everything looked good to go until the spark plug issue. I called Trickflow during my research. I was under the impression you could install the HP manifolds on these heads and that the plug would allow plug wire clearance. It seems I can't use the champions. I have read forums that NGKs? will work?
Does anyone have the HP manifolds installed on these heads? What plugs did you use? My engine has 10:1 compression.
What plug heat range advice?
Any advice would be greatly appreciated. I'm at the end of the install and want to crank this engine up.....
Thanks in advance!
Thanks in advance!
