Hey a big issue with most dual points except what was noted id check the ground between the distributor and the block. A metal gasket is needed, a fiber one will not conduct the ground, and just the ground through the clamp is iffy if the distributor is painted. Also double check the condenser easy check . If you have a noise suppressor condenser check that also usually on the coil.
Here is one way will not check the capacity though more of a pass fail. Use a analogue meter!
www.forabodiesonly.com
How To Check a Condenser on a Points Ignition
I get asked this all the time. I have a condenser tester but I do it daily. This will work for you. This is for an analog meter but a digital works--you will see the voltage spike. Hope this helps 1.) Remove the condenser from the engine (or...
