Rust removal, better than evaporust and 10x cheaper..
icetech
Macomb Mi
soo.. so in doing my car which was a michigan car i have dealt with a lot of rust and spent way too much money on evaporust that i finally went online and looked and found this guys video and made his mix and it worked better than evaporust and lasts longer so far. Sadly i'm down to only a few parts to put back on but my rear bumper brackets were pure scaley rust and nasty.. I wire wheeled them to knock off some scale and put them in the tub for 2 days (didn't check after 1. cause busy) and can't believe how well this worked and i mixed up 5 gallons for $5.. and have plenty of the chemicals left over for another 10-15 gallons if needed...
The citric acid (10lb bag) and i used arm in hammer washing soda which was like $5 for 2lb i just grabbed off amazon $25 total for bout 15 gallons of evaporust..
The before doesn't look THAT bad cause i wire wheeled them and they went black.. but they were still pretty much still all rust.. i left the inside of one untouched to see how it would clean up also...
Should took a before pic before wire wheeling :(
EDIT: adding links to the exact stuff i bought, for ease..
Citric Acid
Sodium Carbonate
But.. the stuff works great.. the couple of rust spots are really heavy scale... i just knocked it off real quick and threw them back in the tub this morning..
That guy went DEEP in his experimentation!
Yeah. that's what made me try it.. guy went full science and did the work and he was right :) i hope it saves some money for people here.. plus having a batch last longer is a plus.. my brackets came out way better than i expected
OHHH fair warning! If you do 5 gallons of it, the reaction is a bit.. intense... i spent 30 minutes mopping my garage.. foam all over.. add the chemicals in small batches, let it form then settle.. then add more.. i dumped it all in and it looked like a kids science fair volcano
if you can wait 3 weeks to a month, molasses and water works great....... set it and forget it
Thanks. I'm going to try this. Where did you buy the Citric Acid and what brand was it?
:rofl: Thanks for the heads up! :thumbsup:
I put links in the first post to make it easier.... also a gram scale for measuring is like $12 on amazon helps...
Well, the links weren't there at first so don't feel like you're a dunce lol
No worries. Right now I'm happy to just remember my name and address, so I pretty much just roll with anything.
Yeah, same here it seems....the older I get, the more I need to think about where I put things lol
I got a serious giggle out of this comment.
thanks for the info
I'll have to bookmark this and save for a day I may need it
I finally got around to trying this and it definitely works!
Before:
After (48 hours in solution):
$50.00 for 40 liters (10.5 gallons). $240.00 for 10 gallons of Evaporust.
Citric Acid
Sodium Carbonate
Have you tried the molasses mix? Believe ratio 10 water to one part molasses? The guy in the video talks way to fast and CC barely readable.
